mikkel2326
Hello:
I could use some help. I have an SE/30 with an AsanteTalk LocalTalk to Ethernet bridge. I am trying to get AppleShare working on the SE/30 with a MacIPgw-Virtual machine on my Windows 10 system. To test the Virtual Machine, I downloaded the Basilisk II hfv (MacIPgw-VM-3.0.hfv) image from MacTCP. Everything works fine in with that image on Basilisk II (it is running on a Windows XP machine). I can see file shares and share files.
nbplkup on the VM doesn't reveal the AsanteTalk. Turning it on and off make no difference.
I am thinking that the switch I am using for the SE/30 could be the problem. The AsanteTalk is attached to the Printer port via din8 and the Ethernet cable is hooked to a gigabyte switch. I'm thinking the AsanteTalk I got the bright idea of using my old Linksys WRT54GL as a switch as it only can handle 100mbs. When I made the switch to the Linksys router/switch, there was no difference in result for the SE/30. I cannot see any shares hosted by the VM.
I'm using pretty much standard settings in MacTCP
IP: 172.16.2.2
Router: 172.16.2.1
DNS: 8.8.8.8
Subnet: 255.255.0.0 (255.255.255.0 doesn't work either.)
I've also done the on and off mambo with the AsanteTalk per this thread (https://68kmla.org/bb/index.php?threads/connecting-an-se-30-to-the-network-internet-with-asantétalk.7973/)
Any thoughts?
Michael
IP: 172.16.2.2
Router: 172.16.2.1
DNS: 8.8.8.8
Any thoughts?
Michael
