ScutBoy
A place to show some progress and ask some questions as I bring back this Outbound...
First, I'm hoping I can get some questions answered from folks like Unity that have manuals for this guy.
What are the different status modes of the amber light above the green power light on the left front? With my hacked 19v power supply connected, the light doesn't light, but the Battery DA shows "charging battery". When I had a 16v power supply that I tried since it had the correct plug, the machine would run, but the amber light would stay lit. I'd like to know for sure what this light is or should be telling me. It doesn't seem to be an HD activity light...
The metal box that surrounds the PS gets fairly warm when the PS is plugged in. Is this "normal"?
Last power question. I assume the original PS doesn't have any smarts. Does the power circuitry in the Outbound know how to handle a fully charged battery with the PS connected, or do I need to be concerned about applying a steady 19v from my hacked PS?
Can someone confirm the amount of RAM for the actual system vs. the amount of RAM available to the RAM disk? I assume that the 4mb limit applies to the system itself, but I've seen reference that the RAM disk can be as large as 16MB using 4x4MB SIMMs.
My LCD panel has a flaw in it. Still usable, but I did research the part # trag provided in the original Outbound thread (Sharp LM64135Z). The only retail price I've found published is $400.00, though many Chinese vendors show it as "available" for quote. It seems it was a panel used in industrial control machinery. Anyone have any other sources I might check for this - or know of an organ donor Outbound 125?
Thanks for any info!
