Snial
Hi folks,
I found a SCSI Yamaha CDR400t-NB CD-R drive at my Dad's house, so I thought I'd 'rescue' it ;-) ! It was loose inside the SCSI enclosure so I spent a bit of time drilling some holes in the bottom so I could fix it in place. When I hooked it up to my PowerBook 1400c/166 under Mac OS 8.1 (with the Apple CD-ROM extension) it doesn't seem to recognise any CD inside even though Drive Setup sees it as a SCSI CD-ROM.
The expansion bay CD-ROM worked. I guess the SCSI cable & termination is basically OK, because otherwise it wouldn't have identified the drive. Do those drives need a special driver? Of course, the drive itself might not be working properly, I didn't hear the CD spin-up. I'm not holding out much hope that the PB1400 is fast enough to write to a CD-R, though that would be an amazing bonus if I got it to work and it did!
Any ideas?
Any ideas?
