Trash80toHP_Mini
NIGHT STALKER
I found this thing in the ancient "Current Hacks" box . . . piccies coming up soon, meanwhile: SCM SwapBox
At any rate, there seems to be a lot more information around for these things than was the case 11 or 12 years ago, thanks to the Linux gang.
Best Description I've found, at least I think this is what I have:
http://www.murga-linux.com/puppy/viewtopic.php?t=75787&sid=e7263cfe7b1496f575507e9bdfd349d1
Interesting little adapter, 3.5" form factor and it appears to run off termination power . . .
Unless SCM snuck power onto some of the alternate ground lines, I've used dirty tricks like that . . . [}] ]'>
< reaches for continuity tester and camera >
Question: does 2-Channel SCSI mean two independent buses/controllers like I think it does? Dunno, doesn't sound very promising read that way.
If that's the case, is there any way to get this to work on a standard Mac SCSI Bus or an a Fast SCSI II Card using two IDs or on a JackHammer's Fast/Wide SCSI Bus?
Might I need to put two identical SCSI Cards into a system to make this work? That'd really suck eggs!
The controller seems very well documented: VADEM VG-469
