Mr. Ksoft
So I grabbed a Powerbook 150, which I've been interested in due to it still being a very late BW/Trackball Powerbook with an IDE drive. I knew going in it had hinge problems, so I thought since it was going to get tossed anyway, I might as well see if I could take drastic measures to fix it. Anyway, the package got stuck in a shipping loop for a while, and when it finally showed up today... the box was absolutely wrecked -- all torn up and crushed and the packing peanuts had mostly fallen out, and to top things off it seems the AC adapter had fallen out of the package at some point and is long gone. The good news is the system and loose screen bezel were completely safe and well packed, so I can still work on that, but I've got no way to turn it on. I've been digging through my AC adapters to see if I can find something that fits the specs (apparently 17W, although the specs I saw for the adapter seem to suggest that it actually is 15W... 7.5V@2.0A) but I haven't dug anything perfect up yet and I'm afraid to try something that's sort of close but not exact, for obvious reasons (5V@2A is the best I've found so far... no good). Can't decide if it's worth the cost to try and find an original, or hack something up that works.
As a consolation prize, it does have a hefty RAM upgrade, so I can always use that in another system if this one is dead in the water.
