Total memory = 640MB; using 2048kB for hash table (at cfe00000)
RAM mapped without BATs
Linux version 4.14.222-g3 (root@pulse.lostwave.net) (gcc version 4.9.2 (Debian 4.9.2-10+deb8u1)) #2 Sat Feb 27 17:23:22 CET 2021
Found a Heathrow mac-io controller, rev: 1, mapped at 0xfdf80000
PowerMac motherboard: PowerMac G3 (Gossamer)
Using PowerMac machine description
bootconsole [udbg0] enabled
Hash_size = 0x200000
phys_mem_size = 0x28000000
dcache_bsize = 0x20
icache_bsize = 0x20
cpu_features = 0x0000000000200472
possible = 0x0000000005a6fd77
always = 0x0000000000000000
cpu_user_features = 0x8c000001 0x00000000
mmu_features = 0x00000001
Hash = 0xcfe00000
Hash_mask = 0x7fff
Found Grackle (MPC106) PCI host bridge at 0x0000000080000000. Firmware bus number: 0->0
PCI host bridge /pci (primary) ranges:
IO 0x00000000fe000000..0x00000000fe7fffff -> 0x0000000000000000
MEM 0x00000000fd000000..0x00000000fdffffff -> 0x0000000000000000
MEM 0x0000000080000000..0x00000000fcffffff -> 0x0000000080000000
nvram: OF partition at 0x1800
nvram: XP partition at 0x1300
nvram: NR partition at 0x1400
Top of RAM: 0x28000000, Total RAM: 0x28000000
Memory hole size: 0MB
Zone ranges:
DMA [mem 0x0000000000000000-0x0000000027ffffff]
Normal empty
Movable zone start for each node
Early memory node ranges
node 0: [mem 0x0000000000000000-0x0000000027ffffff]
Initmem setup node 0 [mem 0x0000000000000000-0x0000000027ffffff]
On node 0 totalpages: 163840
free_area_init_node: node 0, pgdat c04ab378, node_mem_map e7af0000
DMA zone: 1280 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 163840 pages, LIFO batch:31
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists, mobility grouping on. Total pages: 162560
Kernel command line: root=/dev/sda6
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 636148K/655360K available (3760K kernel code, 172K rwdata, 724K rodata, 184K init, 349K bss, 19212K reserved, 0K cma-reserved)
Kernel virtual memory layout:
* 0xfffdf000..0xfffff000 : fixmap
* 0xfd70f000..0xfe000000 : early ioremap
* 0xe9000000..0xfd70f000 : vmalloc & ioremap
SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS: 96, nr_irqs: 96, preallocated irqs: 16
irq: Found primary Apple PIC /pci/mac-io for 64 irqs
irq: System has 64 possible interrupts
GMT Delta read from XPRAM: 0 minutes, DST: off
time_init: decrementer frequency = 16.707883 MHz
time_init: processor frequency = 501.150000 MHz
clocksource: timebase: mask: 0xffffffffffffffff max_cycles: 0x3da751e7c, max_idle_ns: 440795202974 ns
clocksource: timebase mult[3bda1bd6] shift[24] registered
clockevent: decrementer mult[446f7c3] shift[32] cpu[0]
Console: colour dummy device 80x25
console [tty0] enabled
bootconsole [udbg0] disabled
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
devtmpfs: initialized
OF: Duplicate name in PowerPC,750, renamed to l2-cache#1
OF: Duplicate name in mac-io, renamed to ide#1
random: get_random_u32 called from bucket_table_alloc+0x94/0x1ec with crng_init=0
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 256 (order: -1, 3072 bytes)
prandom: seed boundary self test passed
prandom: 100 self tests passed
NET: Registered protocol family 16
PCI: Probing PCI hardware
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io 0x0000-0x7fffff]
pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfdffffff] (bus address [0x00000000-0x00ffffff])
pci_bus 0000:00: root bus resource [mem 0x80000000-0xfcffffff]
pci_bus 0000:00: root bus resource [bus 00-ff]
pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to ff
pci 0000:00:00.0: [1057:0002] type 00 class 0x060000
pci 0000:00:0d.0: [10b7:9055] type 00 class 0x020000
pci 0000:00:0d.0: reg 0x10: [io 0x0400-0x047f]
pci 0000:00:0d.0: reg 0x14: [mem 0x81800000-0x8180007f]
pci 0000:00:0d.0: reg 0x30: [mem 0x81820000-0x8183ffff pref]
pci 0000:00:0d.0: supports D1 D2
pci 0000:00:0d.0: PME# supported from D1 D2 D3hot
pci 0000:00:0e.0: [9004:8178] type 00 class 0x010000
pci 0000:00:0e.0: reg 0x10: [io 0x0000-0x00ff]
pci 0000:00:0e.0: reg 0x14: [mem 0x81801000-0x81801fff]
pci 0000:00:0e.0: reg 0x30: [mem 0x81810000-0x8181ffff pref]
pci 0000:00:0f.0: [1095:3112] type 00 class 0x018000
pci 0000:00:0f.0: reg 0x10: [io 0x04c0-0x04c7]
pci 0000:00:0f.0: reg 0x14: [io 0x04b0-0x04b3]
pci 0000:00:0f.0: reg 0x18: [io 0x04a0-0x04a7]
pci 0000:00:0f.0: reg 0x1c: [io 0x0490-0x0493]
pci 0000:00:0f.0: reg 0x20: [io 0x0480-0x048f]
pci 0000:00:0f.0: reg 0x24: [mem 0x81802000-0x818021ff]
pci 0000:00:0f.0: reg 0x30: [mem 0x81880000-0x818fffff pref]
pci 0000:00:0f.0: supports D1 D2
pci 0000:00:10.0: [106b:0010] type 00 class 0xff0000
pci 0000:00:10.0: reg 0x10: [mem 0xf3000000-0xf307ffff]
pci 0000:00:12.0: [1002:4754] type 00 class 0x030000
pci 0000:00:12.0: reg 0x10: [mem 0x82000000-0x82ffffff]
pci 0000:00:12.0: reg 0x14: [io 0x0400-0x04ff]
pci 0000:00:12.0: reg 0x18: [mem 0xfd000000-0xfd000fff]
pci 0000:00:12.0: reg 0x30: [mem 0xfd000000-0xfd01ffff pref]
pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 00
PCI: Cannot allocate resource region 1 of device 0000:00:12.0, will remap
PCI 0000:00 Cannot reserve Legacy IO [io 0x0000-0x0fff]
pci 0000:00:12.0: BAR 6: assigned [mem 0xfd000000-0xfd01ffff pref]
pci 0000:00:12.0: BAR 2: assigned [mem 0xfd020000-0xfd020fff]
pci 0000:00:0e.0: BAR 0: assigned [io 0x1000-0x10ff]
pci 0000:00:12.0: BAR 1: assigned [io 0x1100-0x11ff]
pci_bus 0000:00: resource 4 [io 0x0000-0x7fffff]
pci_bus 0000:00: resource 5 [mem 0xfd000000-0xfdffffff]
pci_bus 0000:00: resource 6 [mem 0x80000000-0xfcffffff]
SCSI subsystem initialized
