This poor Classic II showed up as a full-scale biohazard. The previous owner clearly smoked. Their cats clearly smoked. Honestly, everything in that house probably smoked. I had to save it.
I tore the machine down to the last Torx screw and loaded my 30L ultrasonic cleaner with anything it wouldn’t destroy: case plastics, internal frame, logic board, and assorted metalwork.
The floppy drive was completely stripped, every metal component that could tolerate it went through the ultrasonic bath, then everything was cleaned, lubricated, and reassembled.
The CRT got a full wipe-down, the hard drive got decontaminated, the analog board went through that too. Both the logic board and analog board were recapped. Amazingly, the hard drive worked!
Keyboard and mouse? Same treatment. Full tear-down, then if it could go in the tank, it went in the tank.
By the end, 30 liters of solution had gone from crystal-clear to an opaque yellow.
Fan? You know what they say about "All the King's Horses and all the King's Men?" I replaced it with a new Noctua.
Once everything was clean, I retrobrighted the case, keyboard, and mouse, then reassembled the system, dialed in the power rails, and adjusted the CRT.
And just like that, one Classic II resurrected.
(See attached images in no particular order)
