krishnadraws
First time doing this (and first time working on a Mac SE/30). Attached is the area I'm fixing. There was a lot of corrosion on the board due to an exploded Maxell battery. I've gotten it to a point where it's looking decent. Broken traces are definitely there. My question is: What do I do with the vias? Do I solder them on the other side of the board? I'm referring to the vias below UJ2F258 and the ones that span horizontally to the right from that point. (see photo)
I've also included the underside of the board, which is looking pretty rough.
Any advice or feedback on precautions / best practices for this, particularly from those who have already undertaken such a task, would be greatly appreciated. I've got new F258's, D1, D2, Y1 and RP8's on order and they should arrive this weekend. New battery and 1/2AA battery holder are already here but I can't put those in until I fix all the traces. Also, above BT1 there is a notch where I believe the battery holder peg sits inside. Currently, it's blocked - do I simply drill it out?
Thanks a bunch!
Thanks a bunch!
