SuperSVGA
The M5120 is similar to the M5126, but differs slightly. So if you end up buying a kit for the M5120 for you would be missing the 4.7uF capacitor and would have some extras of other values.In the meantime, while waiting for the machine to arrive, does anyone have experience and can suggest a source for capacitors? Ideally a pre-made kit so I do not mess up? Is the m5120 and m5126 identical capacitor-wise? Ideally in the EU?
So far I found kit for m5126 (https://recapamac.com.au/) and for m5120 (console5)
I'm sure you've already found this list, but here are the capacitors for the M5126:
SMD Electrolytic:
- 4x 1uF 50V
- 1x 4.7uF 25V
- 2x 10uF 16V
- 4x 47uF 16V
- 4x 100uF 25V
- 1x 220uF 25V
- 2x 470uF 25V
I'm not certain if you can recap the power adapter. I suppose it's possible but I've never done it.Regarding the power supply, I found the capacitor values but no kit.
