Re-capping IIsi problems....
shadedream
I hadn't plugged in speakers externally, I'll give that a try. It does click quietly when the board powers up.
shadedream
Well... some good news and some bad news... I made a poor decision and learned a lesson about trying to re-flow very small pins gently with a soldering iron. I will not be fixing that IIsi any time soon, unfortunately.
On the other hand, I re-capped the other IIsi, which was the one in worse shape of the two as far as cap goo goes, flawlessly and it's up and running.
https://imgur.com/a/iSla5SN
I appreciate everyone's help with troubleshooting the first one anyway. I'll worry about getting back to it when I'm a bit more experience with dealing with smaller pinned surface mounts.
PotatoFi
I've got a IIsi that soft powers on, speaker crackles a bit, and it shows a light grey screen for a moment before the screen turns black. Is that the same symptom that you experienced, @shadedream?
shadedream
Since it's been a while I honestly can't recall. I "oops"ed that board anyway so I haven't really messed with it in a while...
