RAM required for DOS card
LaPorta
Hi everyone,
I’m looking to find out what RAM is required to use onboard the 6100 DOS card. My research tells me it is quite a bit speedier with it’s own RAM. What’s the max you can add on there, by the way?
NJRoadfan
It should take the same RAM as the 6100 does. Any 72-pin FPM 70ns SIMM should work. 16MB modules definitely work, don't know if 32 or 64MB modules will.
360alaska
I have one in my 640, they are very fussy as far as ram, but they will take a 32mb sim.
BadGoldEagle
I've even heard reports saying that 64mb SIMMs work. But getting a 32mb FPM is the recommended route. Plus, I don't know if that much RAM is even that useful in a 66MHz DX2 machine...
LaPorta
Much appreciated, all. I think that 32 is all I'd need anyway as far as being able to run simple games (Wolf 3D) and such. Just need to find some now.
