Radius MagicBus was a compact version of the SE PDS used on Radius' products for the SE. It allowed Radius graphics cards to be used along with a Radius accelerator, and if you didn't have an accelerator, you could use a "jumper card" which was just an adapter.
I have been unable to find the pinout for the MagicBus connector, so when @mg.man dropped off a spare jumper card, I thought I'd better buzz it out and see what the pinout looked like.
A CSV file is attached. Some consumption notes to go with it:
- MagicBus pin numbers and row letters follow the silkscreen on the jumper card, as above.
- Where a pin on the MagicBus connector goes to multiple pins on the SE connector which are commoned together, the "SE pin" column contains the first one I found. No pattern beyond that.
- I checked this all twice, but if you blow up something irreplaceable, that's on you... ;-). If you use this info, please at least check that the 12V is in the right place before you plug anything in.
- Signal names are taken from from Designing Cards and Drivers, p.264.
- I have only done this based on the jumper card. I cannot rule out that, for example, one of the pins marked as GND in this CSV file is actually used to communicate in some way between the accelerator and the MagicBus card. YMMV.
