If it’s working, I’d say leave it. The RAM clips should hold the module in place well enough to get decent contact. Worst case, an intermittent connection could cause a crash, or maybe damage the RAM if it was a power pin. Trying to bend the pin further is just risking breaking it off, and then you’re out of luck until you can replace the connector.
