Quadra/Centris 610 C50 circuit connections (voltage rail?)
RandomDamage
I've got a Centris 610 logic board that I recently recapped. I replaced all the leaking electrolytic caps with tantalums. It is working, mostly, though seems to exhibit some instability. I do notice that I don't get much for voltage across C50. Can anyone confirm if there is a DC voltage across this cap? I measure less than a volt and don't seem to have continuity between the positive terminal (or the via it is connected to) to any other voltage rail (that I've been able to identify).
Thanks!
Thanks!
I'll double check tomorrow, but I believe that C50 is between 5v and gnd.
