KGLlewellyn
Hey all,
I recently got a pair of Quadra 950s, initially both ran just great, but one soon developed a fault. The machine chimes, completes the RAM test and loads up video, it looks like it gets to just the point before it initializes the toolbox, and then just hangs. The grey screen still has the sharp corners, it doesn't get to the point when the corners go rounded and the cursor shows up. I don't get any death chimes either. If I hit the NMI button, I do get the normal sad mac screen with the usual error code you get when hitting NMI before the OS starts loading.
It does this regardless of whether the hard drive is plugged in or not, and the drive is still set not to be terminated, per the requirements of this model. Plugging anything into the external SCSI bus makes no change.
It kinda -looks- like a SCSI issue, but I cannot be certain. Has anyone got any ideas on this one?
Thanks,
Kai
Thanks,
Kai
