I use netatalk (2.2 series) extensively, so if you have any questions I'd be glad to try to help out. It's about the only thing that will work from system 3.3 through to the latest OSX.
To allow guest access, you need to enable the guest UAM module in afpd.conf. I use the following line in afpd.conf:
That allows guest (and only guest) access, and guests will have the privileges associated with the local user 'bbraun'.
The -transall just means both TCP and DDP (appletalk) access is allowed.
Code:
- -transall -uamlist uams_guest.so -guestname bbraun
