Pre made images for bluescsi with games?
crazyfrog
I'm following a steep learning curve trying to setup my color classic with games and finding plenty of apps and game images from macintosh garden wont mount or arent readable by bluescsi or mac os. Has anyone made a image of 7.6 with a load of applications and games installed so I can enjoy the computer a little while I learn?
BetaC
If you're using hda files, and have access to something that can run 10.4 or lower, you can just mount the hda after renaming it to dmg. You might also want to use some sort of emulation to get things installed to your images.
crazyfrog
I currently don't have something compatible with 10.4 but I might look for a mac mini this week.
there is an image with games here: https://archive.org/details/macpack-20210807
I would also like to know if there are others
Looks good but I dont know how to convert that from .vhd for Mister to .hda for bluescsi
68kPlus
Just rename the .vhd to .hda - that's what I did and it works fine.
