IIfx
I realize that the tunnel vision issue is a fundamental problem with the sealing of the active matrix greyscale LCD panels. Is there any known workaround for the more mild cases of the problem? For example, my PowerBook 180 only gets 2 dark screen corners on the left hand side, they do not grow very much and do not interfere in the usage of the system. It takes about 3 hours of use for the dark corners to manifest. Both of my PowerBook 170's are not impacted by this problem yet, so I assume that their panels were correctly sealed from the factory.
Could modding some desiccant into the LCD housing resolve my small symptom of the tunnel vision problem?
