ried
I recently acquired a Daystar Technology MACHSpeed G4 upgrade for my Pismo. It's a 550 MHz G4 installed on an original Pismo daughter card. It works intermittently, with a peculiar issue.
Sometimes, with the machine off, the CPU and its heatsink will become very hot and the machine won't power on. So I remove the batteries and unplug the power adapter, then let it cool off. If I remove the heat shield and apply light pressure to the daughter card (over the 300-pin connector?) in just the right way and press power, it'll boot. Take hands off of the daughter card, reinstall the heat shield, as well as the keyboard, and it'll run fine.
Attempting a reboot, however, often - but not always - makes the problem come back.
I have already swapped out the logic board. Same behavior on both, so I am led to believe this is an issue with the G4 daughter card. Any way to tell? Would that be repairable?
Thanks in advance.
Thanks in advance.
