pcamen
I've got my trusty 540c that I've been using for a while to archive floppy disks. It's got an internal SCSI2SD Powerbook edition that it boots from, either into 7.6.1 or 8.1, and an external SCSI2SD v6 that I use for storing the archived floppy images for easy copy to my modern Mac.
Some time ago, a couple of months, I was no longer able to copy data to the external SCSI2SD. It just seems to fail on quite a few file copies. Take for example three disk images I have. I copy the folder with them, each about 1.5MB to the external SCSI2SD. It will sit there for a while, trying, and then eventually give me an error "The file "file name" couldn't be written because a disk error occurred. Do you want to continue copying?"
I am running this on my PB540c with an external power source, and I've verified that termination is enabled.
What I've tried:
- Different HDI-DB25 SCSI cable
- Different v6 SCSI2SD card that works fine on my Lombard
- Running TechTool on the drives on that SCSI2SD - it found some file level issues but nothing substantial
So basically, both of my v6 SCSI2SD's run fine on my Lombard and I can copy to my hearts content on and off of them, but on the PB 540c, it has a problem every time.
I suppose my PB540c might have SCSI issue, but the internal drive works fine. I could swap everything into a different 540c and see if that changed anything; I'll probably do that.
Anyone have any other ideas?
What I've tried:
