directive0
Hey all!
Preface:
I had a Powerbook 5300c with a cracked screen, Beachycove gave me a 5300c with a dislodged power socket. With the magic of screwdrivers, solder and take apart guides I now have a (mostly functional) Powerbook 5300c that is an amalgam of the two! Thanks to this process I had two IDE HDs to try. I booted the laptop with Beachycove's HD and got the question-disk. Replaced the drive with the HD that came from my 5300c and got another question-disk. So okay -I thought- I've had great success with CF on my 7100 so I ordered a PCMCIA->CF adapter and waited!
Method
Well it came the other day and I decided to try it out using the CF I formatted and had installed in my PM7100's Aztec CF->SCSI adapter. The card was an 8Gig card with a system 8.5 disk and just popped it into the adapter, put the adapter into the book and booted up; success.
I shut down, removed the card and mounted it on my MacPro in Tiger to copy the system folder off this 8Gig card and copy it onto the 4 gig CF card. I used tiger to partition it to many different setups; 1 partition, 2 partitions, 4 partitions. All formatted as HFS (mac os standard). Sometimes partitioning worked, sometimes it didn't; I would often only get one partition to work before Disk Utility would stop without report and leave the rest of the partitions unmounted. I tried restoring the disk from a Mac OS 8 installer image I had made but no luck there either. No matter what I tried the system gives me a question-disk and then forcibly ejects the card. My goal is to get OS 9 on both this powerbook and my 7100 in the future so I would like to acquire the magic skill of transferring system folders and disk images to external media. I gave up on the 4 gig card and went back to the 8Gig that I know works.
So now I want to get the internal drive working. It seems unlikely to me that both drives are completely hosed. I booted up Drive Setup to see if there was anything there, but it only recognizes the 8Gig card. Is this indicative of anything? I can still hear the drive spinning.
Conclusions
The machine runs MORE than competently on the CF card in the card slot, in fact it runs circles around my big clunky 7100/80. File browsing and applications are snappy, and I've only had one instance where the finder crashed from a memory famine. The screen size leaves much to be desired but I found an external video cable for it so I will eventually try to use that, despite the screen having those classic colours I've always loved. Its so good to have this little guy back. I remember stealing it from my dad's bag at the cottage to mess around with Spin Doctor and Super Maze Wars, or use Photoshop Elements that came with his Olympus digital camera to superimpose flying saucers on our sunset photos. HA. I was spoiled, man.
Future Goals
-I also bought an IDE->CF adapter so eventually I want to replace the internal drive with a card permanently.
-I want to get this networked.
-I want to install OS 9 on it.
So...I ASK 68k MLA:
-Are my 4 gig card headaches an issue with the type of card or do you reckon the 4Gig card itself is borked or somehow otherwise unsuitable?
-Is it possible to use any standard PCMCIA->Ethernet adapter with this laptop for networking, do I need to steer clear of cardbus cards?
-What software title would you recommend I track down to properly assess the drives that are connected. Is there anyway to see whats on the chain but not mounted? If this software is included in a specific Apple install or diagnostic disk could you please tell me the name?
-Does anyone have a link to some helpful advice regarding restoring disk images to existing either HD or CF partitions? I appreciate tutorials if you have them, or a thread here regarding the same topics.
Bonus Photos
Thanks for reading!
Preface:
Method
Conclusions
Future Goals
So...I ASK 68k MLA:
Bonus Photos
Thanks for reading!
