Alex
Hello
One of my 2400c's is experiencing GLOD so after a complete teardown all fuses were checked and continuity on those fuses exist telling me they are not the cause. In the meantime I took the opportunity to document all the fuses I could find and post images of their locations here for others to take advantage of. Please note that there are three logic board types from my research.
I hope these images help. In some case you may need to click the image to see a close up view yielding more detail. What is poorly documented here are the J connectors but that was not the main driver of this post.
PB2400_Main_Logic_Board_Bottom_IMG_1358
PB2400_Main_Logic_Board_Bottom_IMG_1359
Fuse F4, F5 PB2400_Main_Logic_Board_Bottom_IMG_1356
Fuse F3, F4, F5, F7, F8, F11 - PB2400_Power_Circuit_Top_Fuse_Locations_IMG_1353
Fuse 2 F2 - PB2400_Power_Circuit_Top_Fuse_Locations_IMG_1352
Fuse F6, F9 - PB2400_Power_Circuit_Bottom_Fuse_Locations_IMG_1355
PB2400_Power_Circuit_Bottom_IMG_1347
PB2400_Power_Circuit_Top_IMG_1346
J8 - PB2400_MLB_Top_Jumper_Locations_IMG_1336
J9, J11 - PB2400_MLB_Top_Jumper_Locations_IMG_1337
J1, J5, J6 - PB2400_MLB_Top_Jumper_Locations_IMG_1338
J2, J3, J4 - PB2400_MLB_Top_Jumper_Locations_IMG_1339
J7 - PB2400_MLB_Top_Jumper_Locations_IMG_1340
J10 - PB2400_MLB_Top_Jumper_Locations_ROM-Switch_IMG_1341
PB2400_MLB_Top_IMG_1328
PB2400_MLB_Top_Fuse_Locations_Liberating_Cardbus_IMG_1331
Fuse F5 - PB2400_MLB_Bottom_Fuse_Locations_IMG_1333
Fuse F1 - PB2400_MLB_Top_Fuse_Locations_IMG_1332
Fuse F2 - PB2400_MLB_Top_Fuse_Locations_IMG_1330
Fuse F3 - PB2400_MLB_Top_Fuse_Locations_IMG_1329
Fuse F4 - PB2400_MLB_Bottom_Fuse_Locations_IMG_1334
- 2400c/180 with jumper cables (forces machine to adhere to 16 bit PC card type) - from what I've read this is the most common type of 180MHz machine
- 2400c/180 without jumper cables (forces machine to adhere to 16 bit PC card type)
- 2400c/240 with cardbus (32 bit PC card natively enabled)
