warmech
Title really says it all - picked up a cheap PB170 that powers up, but gives the boot chime followed by the ol' two sets of error chimes. That's all fine and dandy, except there's also garbage on screen (seen below). I've done some research and checked the PSU (it outputs the correct voltage under load), removed the memory expansion, and given the board a good cleaning, but have seen no improvement. The battery was leaking, but the logic board showed zero signs of corrosion (thankfully). I also pulled the four RAM ICs to check for toasted pads and, curiously, found one on the top side of the PCB. I bodged a wire from the corresponding via to the pin on the chip, but still no improvement. Is it safe to say this board is just toast?
Additionally, if it is just toast, would the following images be indicative of a bad screen or a bad logic board? There are a couple of cheap 170s on eBay in crap shape, but otherwise working. If these are just screen issues, I may just grab one of them and swap the logic boards out. Thoughts?
