Hi All,
I am working on a revival project of a Powerbook 160.
I have recapped the screen and the inverter so I am at a point I have some results but also some problems...
Using an external Bluescsi and without psram extension module and internal hard disk the system boot into 7.5.5.
He complain about to low memory for extensions but boot and everything look working.
Now the remaining problems :
- As soon as I try to install the psram extension module I got the death 8 tones sound and nothing on the screen.
- The Quantum hard disk dampers are like glue. One is near the head magnets and easy to change but the second is below the plates.
Because the disk has 3 plates there is no chance to remove the plates, change this damper and remount the drive. He is definitively lost.
The question :
Can I confidently change the psram module (or may be the chips on the board I will see) or is it possible that the problem is on the daughter board and not on the psram module itself ?
Is there possible to use any scsi 2.5" hard drive ? Or should it be Apple branded ?
Thanks for advices.
Regards.
Philippe
The question :
Thanks for advices.
Regards.
Philippe
