PowerBook 145B CAN run System 7.0.1
PB145B
Not sure how many already know this, but Wikipedia is wrong. It states that 7.1 is the minimum it can run:
Yes, it incorrectly reports as a 140 (well, that’s essentially what a 145B is, with some small changes), but It doesn’t seem to cause any trouble.
And yes, the picture is dark and terrible, but you can clearly see the screen.
All these years I thought it couldn’t run 7.0.1...
PB145B
Okay, I managed to successfully image it with DiskCopy on my PowerBook 170, and it does indeed run just fine on the 145B!
Really crazy seeing System 6 on a PowerBook! Might format one of my spare drives and throw it on there just to see how it runs from a hard drive, though I still prefer System 7 on here, as it has more features, more software works with it and it supports 32-bit addressing.
PB145B
I went ahead and installed 7.0.1 on the 145B’s hard drive, as the original 7.1 install had a few little issues and I already had it on floppies anyways. Runs great. Seems a tad but snappier than 7.1, but that may just be my imagination, or the fact that it’s a fresh install.
CC_333
I think I like 7.1 a tiny bit better, because it has a Fonts folder, so one doesn't have to use special tricks to install fonts into the System file.
It's also slightly more compatible with 7.5-era applications and utilities, I find (the fact that pretty much all systems from 7.1.x to 7.5.5 used Finder 7.1.4 (or some variant thereof) might partially explain why).
c
PB145B
I think they are both good.
I figured since 7.0.1 ran great on my PowerBook 170 I’d throw it on the 145B as well, since it actually can run it.
