HAL2001
Hi,
I bought the CF2IDE print and a 64GB CF card. Yes I know, 64GB is ridiculously large but I got it cheap. I own a PowerBook 1400cs 166MHz and I want the CF as my start up disk. I can read and write to the CF card on the CF2IDE card in OS 9 on another PowerBook. The 1400cs has 8.1 on it. I formatted the CF card with 1 partition in MacOS standard. I copied the contents of the old hard disk to the CF-card but I am not able to make it my start up disk. The PowerBook doesn't't see it. I am able to start up from it using a CF-reader in the PC card slot. It works great in there but when I attach it to the internal IDE-cable it doesn't work at all.
What am I doing wrong? I tried 2 partitions. One which was 11GB. That's the same amount as the original hard disk is so I thought that should work. But I read that a partition of 64GB should work in OS 8.1.
Okay, who has some thoughts?
Thanks!
Thanks!
