Power Mac G4 Help Me Identify A Replacement Component!
jajan547
Hello everyone I appreciate any help anyone can provide. This component was lost on this board I am fixing for a friend and I have no clue what replacement to order or where to get it or what size and value I need. Thanks again!
herd
It looks like you fixed the crystal and the smashed component is probably just a bypass cap so its value would not be critical. The chip is probably ok, unless that one pin on the end is broken? I've repaired broken pins by grinding away the plastic enough to expose the internal copper enough to solder to.
What is this from, a MDD?
jajan547
This is the motherboard of a 1.25GHz power Mac G4 so I can just bridge it or do I leave it?
alectrona2988
Appears to be a small capacitor. Sometimes a computer could live without one, but the traces seem to be going to a chip which may have importance. I probably wouldn't bridge that, unless you're overclocking and you need to connect 2 PLL pads together, LOL.
jajan547
Any idea what value the component may be?
jajan547
I have to look when I get home in about an hour and a half I know it’s the 1.25ghz mud model
jajan547
Well, that's easy to figure out. Just a moment...
EDIT: There does not appear to be a schematic for your board. Try checking the other 2 caps' values with a multimeter.
Accurate.
Lol I will when I get home.
Nixontheknight
Would bridging the pads where the cap was do any harm?
Nixontheknight
It would likely short the power rails if it's a bypass cap. In general capacitors are DC blockers, so approximate an open circuit at DC rather than a short, so bridging where one was is almost always a bad plan
Noted. I unbridged the connections before powering it on (because I did bridge them while it was unplugged)
