Power Computing PowerBase & PowerCenter Boot issues
macinbot
I've got a few Power Computing machines I need help troubleshooting.
None of them seem to want to boot. I get no start up chime or video output from any of the machines.
I have two PowerBase 180 machines and a PowerCenter 120. The PowerCenter has booted without issue in the past, but has been sitting for a couple years unused (climate controlled). The PowerBase machines I acquired without knowing their boot status. This is first time I've tried to revive them.
They all power on. All do a cursory power-on poll of the CD-ROM. On power up, PowerCenter will poll the hard drive. The PowerBase machines don't seem to do that, but that may be an IDE thing?
Things I have tried:
  • Reseating all the cards including processor card, PCI riser, cache, and ram
  • Pulling all ram and using known working ram from PowerMac 5400 (is there a preferred single ram slot?)
  • New 3.6v battery installed
  • Reset CUDA switch
  • Used both Apple Performa Plus 640x480 DB-15 display and VGA monitors
  • Cursory examination doesn't show any obvious signs of capacitor failure
What next?
MJ313
These machines can have cache modules that go bad for whatever reason. Try removing the cache and booting without it; it's a relatively easy thing to rule out.
macinbot
The PowerCenter and one of the PowerBase machines had a cache module, the other PowerBase did not. Pulling the cache on the two machines made no change in starting up. I also swapped the cache into the other PowerBase just to rule that out, and it also made no difference.
macinbot
Tried using an replacement ATX power supply to see if that made any difference. It did not.
Very open to suggestions.
macinbot
Well hmmmmmm. These machines are outside of my interest vs investment ratio. I think its time to move them on to someone who has more drive to restore them.
Appreciate the reply.
_AP
I'm having the same problem. I've tried a power computing monitor, and older dell LCD.
I've tried:
VGA/DB15->VGA
New PRAM battery.
Re-seating/cleaning contacts of cards, cpu, memory.
CUDA resets.
Original CPU and newer tech upgrade.
Removing cache card and trying different memory configs.
PRAM reset with keyboard.
I have tried these same things on:
2 PowerCenter Pro minitowers
1 PowerCenter Pro desktop
1 PowerTower Pro
1 PowerBase 180
No visible problems with capacitors. No corrosion anywhere. None of them have hard drives in them, but when I picked them up and tested them beforehand, most of them had drives in them had same results.
Unbounded_Villain
I've tried:
VGA/DB15->VGA
New PRAM battery.
CUDA resets.
1 PowerTower Pro
1 PowerBase 180
I had a PowerBase 180 back in the day and the PCI riser is early unseated.
