Pismo drive replacement - what type of SSD do I need?
FacnyFreddy
So, I decided to revisit the mSATA <-> IDE adapter from Ablecomm with the "red" board.
What I found out is that the Ablecomm board "likes" Samsung PM851 and PM871 mSATA ssd drives (500GB or less)... it really HATES Toshiba branded mSATA boards.
I'm going to see if this board with mSATA adapter will fit correctly with a $7 copper heat sink attached to help conduct heat away in my G4 Powerbook.
NOTE: These need to be in "master" setting for drives... (no jumper on the end pins)
The white/black mSATA <-> IDE 2.5 drives that are like $15 run a bit warmer but LOVE Toshiba branded mSATA SSD drives. I think they work with Hynix as well, but, I've not tested one first hand.
NOTE: I don't believe these support any jumper settings from what I read else where. You use them "as is".
I tested both boards in my Powerbook 5300 (Os 8.1), G3 Pismo (OS 9.2), and my G4 A1106 (OS 10.4 and 10.5).
Skate323k137
This combo works great in my Pismo (also put the same in my iBook G4):
Ableconn IIDE-MSAT mSATA SSD to 2.5-Inch IDE Adapter Converter with Aluminum Frame Bracket - Latch and Retain mSATA SSD as 9.5mm 2.5" IDE SSD Drive
https://www.amazon.com/gp/product/B017VQT5YW/
$29.99
Transcend 64GB MLC mSATA SSD TS64MXT1CC
https://www.ebay.com/itm/352520351672
$22.95
Going to give this a try in my Pismo, TY for the info. I have CF stuff on hand but never wanted to do the work to replace it with CF. mSATA sounds much more motivating.
(Sorry if bumping like this is frowned upon here)
LCARS
I use a mSATA (in 2.5" enclosure) in a 1400c and a Pismo and its wonderfully quick not to mention quiet. So far so good. And yes, don't forget to disable Virtual Memory if you've got max'd out RAM.
To note: I used a Dogfish mSATA drive at 128GB and run it under 9.2.2
