Mighty Jabba
I got this "untested" eMate on eBay for $35 shipped, which seemed like a heck of deal. Even included a nice stylus. I figured even if it didn't work, it would be a cool object to have. I had a couple of Newtons many years ago, so I am still kind of familiar with the OS, but have never had or even used an eMate. It didn't come with an AC adapter, and while I have heard of people potentially damaging their eMates using third-party adapters, I was pretty reluctant to buy an adapter without even knowing if this thing worked. So I found one that I had that seemed close and tried it. The green LED turned on, but there was nothing on the screen. But after a bit I realized that the contrast was just adjusted all the way down, and it was working fine!
My first question is, if this adapter seems to power it fine, should I worry about trying to get a genuine adapter? Is there any chance that the internal battery still holds a charge?
Also, the clamshell seems extremely difficult to open (the hinge seems unnaturally tight) but closes normally. I've heard about ribbon cables getting messed up on these, so I think I will just leave it open all the time for now, but does anyone have any ideas about what might cause this? Anyway, I'm excited to play around with this.
