jack
Hello 68k MLA folks,
I recently aquired a Classic II (actually a Performa 200...). When I first got it, no startup chime and vertical bars, the usual symptoms of leaky capacitors.
Cleaning the logic board allowed it to start and System 7 works great on it, but there was no sound. I connected my cell-phone using alagator clips to the speaker and was able to play music on it (at low volume), so I figure the speaker was ok. Figured some of the caps needed replacing, so I went and replaced all the caps on the logic board.
Even after replacing all the capacitors on the logic board, I still can't get any sound to work. Any ideas what to check next?
Thanks.
Thanks.
