No Ethernet with Kanga after update to 9.2???
hilga007
Hey there!
I am selling my Kanga on here and decided to test everything out. I am having a heck of a time getting it to browse the Internet! TCP/IP control panel is enabled, and everything seems ready to go, except for the fact that its just not working and I have no idea why.
There is no "activity light" on my router, which indicates its coming from the Kanga's end.
I had to use OldWorldSupport (OS 9 Helper from macsales.com) to bring this laptop up to that level, as it natively only supports up to 9.1. Does anyone know of anything in regard to this? Otherwise I will have to just reinstall 9.1...
Quadraman
The Kanga is a funny machine. It's more like a 3400 with a G3 upgrade than the later G3 Powerbooks. If you're selling anyway, I'd just roll it back to 9.1 where at least everything works and let the buyer worry about reconfiguring it for 9.2.2.
MacG4
yeah do a roll back and see what happens.
madmax_2069
have you tried to delete the pref file for TCP/IP. have you tried to wiggle the cable around a bit wile its connected to the port and on the router( just wondering) have you tried to use a different cable ( i know it sounds stupid)
that is if you already haven't tried al of those above.
hilga007
Yup, thanks for the advice, but I've done every piece of troubleshooting I can, and narrowed it down to perhaps a driver issue for 9.2.2. I will be reinstalling 9.1 shortly.
MacG4
cool let us know what happends
hilga007
Restoring to 9.1 seems to have solved the problem, so it must be an issue with the "OldWorldSupport" and some drivers there...
