BadGoldEagle
Hey there
My first post here in the Newton section.
Just bought myself an OMP for €50. I consider this cheap since I got the original box as well as all the documentation, the VHS tape, two pens, original power supply, warranty etc...
It works well, although the audio seems to be a bit low. You can barely hear it. It doesn't matter now, audio isn't important in a Newton, right?
I got the "getting started" card along with it, but it won't work. It tells me that this type of card can't be recognised.
The guy I bought it from said it was never used as it was part of an experiment at work: they wanted to know if it was worth it to deploy Newtons in his service. Apparently it didn't work... Handwriting recognition was pretty appalling he told me.
He left the card in the slot for 20+ years. I don't know what damage could have occurred to the card during that time.
Is it possible to fix it?
Newton asks me to erase the card in the slot, but aren't those "getting started" cards ROMs?
Is it possible to "flash" a Newton Card from an image available on the internets?
I apologise if I'm asking the wrong questions, but I'm a Newton novice.
Here's a picture of it:
