Johnnya101
Hi all,
My Powerbook 140 clicks randomly, but has an SCSI2SD, good screen, etc. I bought a 145 off ebay.
It was to my knowledge that 140s, 145s, and 170s have the same logic board, but CPU boards are different.
I first tried swapping the entire bottom but installing my SCSI2SD. I did this, plugged in the main cable, installed the bottom, and plugged in a power adapter. It started chirping loudly. I then noticed it was my unrecapped adapter. No big deal, it just needs the caps replaced. I swapped it with my KNOWN GOOD recapped adapter. Same thing, chirps loudly.
Next, I opened it back up again and removed the CPU card from the 145 and installed it in my 140 bottom, and installed it with my 140 top (Keep in mind all 140 stuff is known good). Plugged it in. Chirped once quietly (Like it should), and turned it on. It chimed, lit up the screen. Yay! Then all h$#% broke loose. The speaker started buzzing super loudly and the screen had gibberish and lines all over it. I quickly unplugged it.
What the heck is going on here? Am I wrong, 145s are not compatible at all with 140s? Or is my 145 completely dead? I dont want to try anything else until I find out whats going on. Bad 145 CPU board? I know the 145 logic board is junk, it makes the adapter chirp when plugged in and not even on, so not even gonna attempt to use it.
Got a modem card and RAM card out of the probably dead 145 though.
