Nasty Time Bombs Removed Just In Knick Of Time!!
KGLlewellyn
TWO Maxells in one Mac...I would not have wanted to see the results if both went off. Oof.
Nice catch!
Johnnya101
Wow, that was close!
Sidenote: Why is it that some people seem to only find Maxells, and some almost never find them? Was it regional? In probably the 30+ Macs I've come across, I have only found one intact one...
macuserman
Hmm I've found quite a few I have some machines that did explode already. This is my first macintosh II not sure if I'll keep it or not but I want to play with it at least first and I couldn't wait to get those batteries out when I saw them.
Johnnya101
Forgot the edit was removed, so ill reply. Meant to say ive only ever found one maxell.
Byrd
One is bad enough, two Maxells - that's enough to start a small turf war!
I've come across mostly Maxells in early 68K machines, but picked up a B&W G3 recently which had a Maxell.
macuserman
Hmmm well I may have spoken to soon about saving it just yet lol. I am getting zero signs of life out of it when I try to power it on.
macuserman
Anyone have a test procedure or at least a pinout for the Macintosh II PSU? Be nice to first figure out if it's a PSU or board problem. Board looks really good though so I'm betting PSU.
bibilit
Have you got a pair of brand new batteries ? The Macintosh II series will need ones to kick the boot process (there's a trick shorting two wires on the PSU connector though)
macuserman
Ohhh hmm nope, I have some batteries, but didn't put them in this is my first macintosh II that I've played with so I was not aware that they required the batteries to boot. On machines I've used in the past that required it, they would usually power on but just not boot, this isn't doing anything at all.
macuserman
Just put fresh batteries in it but still nothing so unfortunately that wasn't my issue.
macuserman
Your board has the original electrolytic SMD capacitors, it needs to be recapped.
These Mac IIs also have a tendency of problems with their start-up circuit which is documented here: https://www.downtowndougbrown.com/2015/03/explanation-of-the-macintosh-iiiix-power-onoff-circuit/
My Mac II wouldn't start even after it was recapped because of a bad trace in the start-up circuit.
Ugh yeah I was thinking I'd need to do that, I guess I need to find a list of caps to order or sit and look them all up on my own but rather just order them and have them on hand before disassembling.
macuserman
Also not quite sure how to safely remove the adapter to get at the caps and areas around/under it for inspection.32EF22B2-7259-4C20-85CE-867F0A15E104.jpeg
macuserman
I know you can get a puller type device or at least I've seen pictures of them for the original CPU chips by itself, but these big adapters no idea how that would even work on one, hate to damage it trying to remove it.
macuserman
joshc
It's a case of new ROMs and changing the IWM chip to a SWIM chip.
More details on the FDHD upgrade here:
Also more detail here
Post a photo here of your chip and someone will be able to identify if its an IWM or SWIM.
macuserman
It says IWM next to the chip but I suppose that doesn’t mean it hasn’t been changed I was hoping it was already modded because the floppy drive looked like a 1.44mb drive.
KGLlewellyn
I get what you mean. I've never seen one, and I've collected a lot of machines over the years in NW US and UK.
