So was there anyone that did analysis on these, to figure out why they leaked,
I know the cooling system was designed by DELPHI a division of GM, looks like they basically used an Aluminum A/C evaporator for the Liquid to air heat exchanging process.
The issue with liquid based cooling systems is they will all eventually need some kind of service.
Even with the ford model T, using natural convection instead of a water pump.
I'm sure you could still develop a leak causing the cooling system to fail… or scale build up in the heat exchanger would slow or halt the
convection process.
About the worst you would have to worry about with a hunk of metal as a heat sink (passive heat exchanger) on a cpu is dust clogging it up.
oh and maybe the thermal grease drying and caking, between the HS and CPU, but i think that is just due to poor quality thermal grease in the first place.
well, maybe the fan burning out, those case fans in those G5 towers are aggressive and very good quality.
