Also known as a Houdini cable, for use with an Apple PC/DOS card in a 6100 and some other models.
J joshc Well-known member May 18, 2022 #21 Also known as a Houdini cable, for use with an Apple PC/DOS card in a 6100 and some other models.
C Carlisle Member May 18, 2022 #22 Nathan_A said: Yep, that's a cable for Apple & Reply DOS Compatibility Cards. I have a few here. If you can tell me the model number, I can tell you if it's the version for a PDS or PCI card (as they're annoyingly not the same). Click to expand... 590-2104
