Motorola Marco now working!
MOS8_030
My Newton clone lives again!
Well, I spoke too soon when I replied in to the Newton documentary thread when I said my Marco didn't work.
My problem was lack of patience...
Long story not-so-short, about 15 years ago I was given this Marco. It came with no power supply, nothing except the Marco carrying case.
At the time I tried a regular Newton PS but that didn't work and since I had no documentation and couldn't find any info about the Marco specs, it's
been in the box with the rest of the Newton stuff.
So recently when I got out my Newton stuff I thought I'd give the Marco another shot.
After doing some googling I found possibly the only detailed reference to the Motorola Marco on the web and I finally found the information about the Marco PS.
(Bless you Newtman!)
So I googled the Motorola PN and lo and behold there is exactly one Marco power supply for sale on ebay for a very reasonable price!
So I get the power supply, new backup battery, and Marco still no boot. Darn. Oh well.
Flash forward a few weeks to today and after I posted about the Marco I thought I'd give it another shot.
After about 10 mins on the charger and a hard reset I get the chime and Marco is alive!
The problem was the first time I tried the PS I didn't give the Marco any time to charge the (long) dead battery.
Anyway, the red & green lights are Marco searching in vain for the long gone ARDIS network.
(The dark line on the screen is from the camera shutter sync)
Anyway, :)
Oh, and I found the battery pack for my Messagepad too.
AppleNewtonFan
New member
Hi MOS8_030,
I have Marco, but I can't boot it up. I don't have original power adapter, but I have original dock for charging battery. I just used 12V 900mA 3rd party charger, but I still can't boot Marco. When I use this power adapter with dock, the red light blinking. I'm not sure what it is mean. Any suggestions what I could try to bott this device? How did you manage to make 'hard reset'?
MOS8_030
Hi MOS8_030,
I have Marco, but I can't boot it up. I don't have original power adapter, but I have original dock for charging battery. I just used 12V 900mA 3rd party charger, but I still can't boot Marco. When I use this power adapter with dock, the red light blinking. I'm not sure what it is mean. Any suggestions what I could try to boot this device? How did you manage to make 'hard reset'?
Howdy! Sorry for the late reply, I just saw your post.
Here's where the reset button is located.
http://newton.plumbrook.com/marco/device/dtour/page13.html
Also you should replace the LI battery. It's located under the Motorola logo on the back. (The logo is a cover that twists to release.)
The red light on the dock is probably indicating it's trying to charge or that the battery is bad.
I would try "charging" your bad battery for a while then connect the battery and the power supply to the Marco and try a reset to see it if it boots.
I have two batteries and only one will work with my Marco, the other is completely dead. The Marco needs a battery that will take *some* small bit of charge.
Getting replacement cells for the battery pack would be easy, opening the case not so much...
Maybe someday the user manual for the Marco will get uploaded to the internet.
jsmartinson
New member
How can I get a battery? I have everything else including the elusive users guide. Neither batter works.
Alex
Would you be so kind to scan the manual. It is ring bound so scanning it should be easier than a spine bound book. If you manage to scan at 300ppi please upload it to the internet archive. Your consideration is appreciated.
MOS8_030
How can I get a battery? I have everything else including the elusive users guide. Neither battery works.
Howdy! :)
Nice rig! I've never seen the battery dock before.
Yes, please scan that manual if you can!
As far as the battery, I'm afraid they would have to be rebuilt using new cells. (NiCD)
That would require carefully cracking open the battery case and soldering in new cells.
I have not tried this with my batteries.
Alex
I took photos of the Marco User's Guide and posted them here for download.
Thank you VERY much for taking the time to put this together. I will do what I can to improve the manual, straightening pages and the like and get this on the internet archive (archive.org). Thanks again and good luck with the sale.
Alex
I've already converted the images to TIFF but each one has to be straightened one by one. Does anyone know the old site for the Motorola Marco, I can scrape the waybackmachine if I have some sites. Maybe it's on the manual, I will need to check but feel free to post the old site address here in case.
Alex
ok, I am not going to restrict the download to file types and I will go to 2003. I will report back with anything relevant. If the manual is there in PDF, I will move it to the internet archive straight away. I am doing the entire domain mot.com. 100,000+ files coming down but that's ok, whatever is irrelevant will get trashed and I will do a more narrow download after the fact.
