Missing Pressure Pad (and Shield) from 400K Floppy Drive
RedJacketPress
I've been servicing the 400K drive from my Macintosh 512K -- the drive spins and ejects (and the load and eject mechanism feels great), but it won't read any disks -- it spins up and ejects a disk almost immediately. I think I might have found the reason why -- the felt Pressure Pad is missing, and I suspect the heads aren't making good contact with the disk surface. (I did a bit of disassembly hoping I might find it in the drive, but no luck there.)
(The Shield is missing, as well, though perhaps that was a change made during manufacturing? This drive is from 1985.)
I haven't been able to find a source for replacement. I'm fairly confident I could 3D print a useful piece, though I'm not sure what material to use for the felt pad that wouldn't inadvertently damage the disc surface. (Though come to think of it, a 400K drive would only read one side of the disk, so perhaps that doesn't matter as much?)
Any suggestions of where to find a replacement or where to find the design for a replacement or what to use as a replacement?
Thanks!
bibilit
This part is often missing, if the drive is stuck and carrier in the upper position, trying to insert or remove a disk will push the felt out of position.
IIRC you can use a similar part from an Apple II drive… or find a faulty drive (not easy i know)
pfuentes69
This topic interests me...
I want to replace mine because is in bad shape and I was thinking that maybe I can use the tool to make holes in the leather belts and make a new felt pad... Or maybe with some patiente cut one with scissors.
I was planning to cut it from one of these adhesive felt pads that are used to put in the chair legs...
mg.man
Unconventional, I know... but I've done this with a Q-Tip on a few drives...
As they say... desperate times... :)
Besides, for a 400k disk the upper surface doesn't really matter. I'd just advise caution and avoid inserting a valuable 800k disk! :p
mg.man
FYI, I usually use a scalpel or brand new utility knife blade to carefully trim away the lower cotton... otherwise there's too much there and the 'tip' sits pretty high. Also... the paper-stem ones seem to be a perfect fit! Aren't the plastic stem ones illegal in the EU now anyway? :unsure:
RedJacketPress
I'm confident enough in the health of the Mac to order (and assemble) a Rominator, so I'll probably just boot from the ROM as a matter of course. But I would like to have a working Floppy Drive.
How does the Q-Tip stay in place? Is it a tight fit?
WillJac
I not sticky felt feet and cut out very small round pieces but had to double it in to knees and stick it on. It works. One piece was not enough pressure why I had to double it.
RedJacketPress
The Q-Tip-as-Pressure-Pad solution worked well, and was relatively easy to implement. I got the Mac 512K to boot from the a System disk, though it got only as far as a blank desktop before it encountered System Error 15 -- I'm thinking this is probably a further issue with the 400K drive, perhaps a failure to access a particular part of the disk? (I did clean the heads, but I don't know that I have the time or the patience to work on alignment issues.)
In any event, I have a Rominator on the way, so I'll know soon enough if this is a problem outside of the drive!
WillJac
You can also try recap the floppy. JDW has a good video on this and mouser carts to get the caps. I did all my 400K drives. I have not done the 800 or higher once yet.
RedJacketPress
That's also an option. I think when I get the Rominator sorted out and installed, I'll connect the drive outside the case and try to get a sense of what it is or isn't happening.
Juror22
I wish that someone had seen my post and had mentioned the Q-tip idea, when I asked about this a few months back. I went out and spent WAY too much to get one of these pads.
That's how I tested the last one 400K drive I bought. (I hooked it up to my external case's cable)
