So I have a monitor that is supposed to work with the video card. I had to switch pins 1 and 2. I might ave to swap pins 5 and 6 but I don’t understand pin 6?
What I found out while looking at the connection to the monitor is that there are the connections:
1 - video signal A
2 - nothing
3 - horizontal sync
4 - vertical sync
5 - nothing
6 - video signal B
7 - video ground
8 - horizontal black - ground
9 - vertical black - ground
What does video A and video B even mean? Both cables go to the neck of the monitor?
Included are some pictures that show the connections.
When connecting to the “Extron RGB-HDMI 300 A" I only use the video A signal so why does the monitor require a video B signal?
1 - video signal A
2 - nothing
3 - horizontal sync
4 - vertical sync
5 - nothing
6 - video signal B
7 - video ground
