I'll sort out some instructions later. Its 5:24amI do but how do I go about this I'm very confused.
It can be done with a SCSI2SD just fine.
Sweet whenever you get a chance and thank you.I'll sort out some instructions later. Its 5:24am
So I looked and found some information on it but being that I've never done it I'm still very confused.I'll sort out some instructions later. Its 5:24am
Its not just the instructions - the disk driver on the disk image needs replacing - from IDE (6360) to SCSI (475).So I looked and found some information on it but being that I've never done it I'm still very confused.
I don’t blame you that’s enough to make anyone want to sleep. So you say it needs to be tricked into thinking it’s something else?Its not just the instructions - the disk driver on the disk image needs replacing - from IDE (6360) to SCSI (475).
Sorry, did a 14 hour working day yesterday. I went to bed when I was done.
The disk image of the disk from the 6360 has a driver at the beginning - but it is an IDE driver. If you copy the whole image onto a SCSI disk, it will have the wrong (IDE) driver, and so won't work.I don’t blame you that’s enough to make anyone want to sleep. So you say it needs to be tricked into thinking it’s something else?
Not to be a complete and utter killjoy…but can’t you just mount the DiskCopy image on another machine, drag the System Folder to the internal HD, bless it, and call it a day?
I use similes too much. Sorry @cheesestraws
Just to be clear, this is all I'm planning to do.Not to be a complete and utter killjoy…but can’t you just mount the DiskCopy image on another machine, drag the System Folder to the internal HD, bless it, and call it a day?
See that’s interesting maybe it’s an extension thing try without, that’s the same thing that happened when I tried before.Pretty sure it won't work on your 475 anyway, I couldn't get it to boot in Basilisk II (it crashed/froze up) but it was fine in Sheepshaver. Now, that could be emulation/driver weirdness but I don't think so, it attempts to boot in Basilisk but got stuck after extensions were loaded. Also, most of the interesting/unique stuff on there is PPC only (there are two internal Apple network/OT testing applications on the drive).
I get an error type 10 when the Finder tries to load.See that’s interesting maybe it’s an extension thing try without, that’s the same thing that happened when I tried before.
Interesting I disabled these extensions that had X's over them in sheep saver and then saved the .hda and copied it to my sd card. When I boot my LC475 it loads up mouse moves but no icons or text ever load in.I get an error type 10 when the Finder tries to load.
Thank you @Johnnya101 for preserving the contents of this drive.If someone had the time, premade ready to go images could be made for SCSI and IDE systems. Probably would need to install 8 on a drive and swap system folders to get things working reliably?
I'll PM you later today to discuss sending it back. Glad we got this done
I’ll give it a try tonight.People have noticed the actual 7.7 Installer is on the disk haven't you? I'd write that to a CD and install a fresh copy ideally. Would be a nice tidy copy for your specific hardware.
