Macintosh SE/30 logicboard recreation (thread revival)
Cam
Don't know if anyone in Canada is looking for a source of 64 pin SIMM sockets, but I ordered and installed these https://www.componentonline.com/product/426B-64-1A/0015821104 and they seem to fit fine, AND have metal release tabs.
The company has a minimum $ order ($30 CDN?) and I'm not sure if they ship internationally.
Shipping was very fast, but then again they're not very far from me; your experience may differ.
Back to troubleshooting . . .
alectrona2988
Where is a good place to buy a PCB like this? I have an SE/30 motherboard that's had some damaged traces and pads from neglect due to (very) bad caps and I'd like to save it with a nice fresh board.
Daniël
JLCPCB and PCBWay are the "big ones" for hobbyist PCB manufacturing, so to speak. I would just go for whichever one could provide it the cheapest, which tends to be JLCPCB in my experience. There are other Chinese PCB manufacturers, as well as Western ones like OSHPark, but they'll likely be much more expensive.
Do note that practically all PCB manufacturers have a minimum order quantity of 5 PCBs. So if you just want one, you'll still get four blanks. You might be able to find people to do a group buy with, or could try selling the other boards to fellow enthusiasts on the forum through the Trading Post.
WillJac
I can probably provide you with one. DM me and we can discuss.
storhemulen
Has anyone been able to use the PLCC for the rom instead of the SIMM? No matter what we do, we can’t get it to boot. With a simm in place it boots right away.
If anyone has had success with these, I’d be very grateful for some rom files so I can compare. Byte swap has been done as per instructions.
Did you ever get it to work with PLCC ROMs? I can't get it to boot either.
storhemulen
Hmm. Does not compute. 😀
1. Swap data bytes, save to new file
2. Split into 4 parts
3. First part goes in RU1
Correct?
Answering myself here...
Should have checked the github page more carefully. Then I would have noticed the files already prepared in the "ROMs" section. Guess I should get the board working with those first and then try to flash my own files.
Since I am using 29F010 flash which holds 128 kbyte, this means I have to pad each 64 kbyte file with itself, right?
Code:
cat SE30stockU1.bin.swapped SE30stockU1.bin.swapped > SE30stockU1.bin.swapped_doubled
storhemulen
Sorry for spamming, really keen to get this working... :cool:
From Bolle's github: "...stock SE/30 ROM split up in to four files and bitswapped".
I was raving about swapping bytes, but I guess the correct thing to do is to swap each bit so that bit 31 becomes bit 0, bit 30 is bit 1 and so on.
Let's say I have a stock ROM file (checksum 97221136) called orig.bin. Would below scheme work?
First splitting the original into 4 parts:
Code:
srec_cat orig.bin -binary -split 4 0 -o rom0.bin -binary
srec_cat orig.bin -binary -split 4 1 -o rom1.bin -binary
srec_cat orig.bin -binary -split 4 2 -o rom2.bin -binary
srec_cat orig.bin -binary -split 4 3 -o rom3.bin -binary
Then using a 4 byte width for reversing all 32 bits of data:
Code:
srec_cat rom0.bin -binary -bit_reverse 4 -o rom0_bitreversed.bin -binary
srec_cat rom1.bin -binary -bit_reverse 4 -o rom1_bitreversed.bin -binary
srec_cat rom2.bin -binary -bit_reverse 4 -o rom2_bitreversed.bin -binary
srec_cat rom3.bin -binary -bit_reverse 4 -o rom3_bitreversed.bin -binary
Bolle
Code:
Correct so far.
When reversing the resulting split files leave out the 4 byte width as the split files are only 8 bits wide:
srec_cat rom0.bin -binary -bit_reverse -o rom0_bitreversed.bin -binary
Jockelill
@Bolle beat me to it, but the above solution works I can confirm. And yes, the ones on Github can be flashed directly to the roms.
storhemulen
It's alive, kind of! My monitor can not sync the 22 kHz signal correctly, but it's enough to tell that I have a mouse pointer that I can move.
Most of the components mounted, but no SCSI or floppy controller yet.
Hooked the board up via VGA and a small adapter board.
Time to mount the remaining components and possibly get a custom ROM flashed.
joshc
Rounded corners and a cursor is good news :) Nice one.
croissantking
Being able to use PLCC chips for the ROM will become increasingly important with the scarce availability of 64-pin sockets.
storhemulen
Phew! I was about to panic and tell you to attenuate that video signal :)
Not to worry. The signal out from the adapter board is below 1 Vp-p. I built the little board here:
storhemulen
A cheerful chime and a moveable pointer on the CRT, which means a little step further for this Reloaded board.
No disk with question mark though. Maybe this is normal behaviour if both scsi and floppy controllers are missing?
We'll see when they are properly mounted.
