Macintosh SE/30 logicboard recreation (thread revival)
JAG
For anyone still interested in buying a PCB, JLCPCB is out of stock on some of the bottom board SMD parts so that's the hold up at this point. I'll likely get purple or blue boards. I'm planning on 10-15 as I have at least 5 SE/30's myself that could use new boards.
croissantking
But you can’t use pick and place if you go for a non-green board anyway…
Juror22
I'm still in for one of them (two if you need help getting enough to order), so keep me on your list! ... and any color is fine.
Oberlehrer
Same here. One board; two if it helps getting the order through (or getting into a different volume discount region).
daanvdl
Did anyone found a (alternative) solution for (recreating) the metal mounting bracket on the PCB yet?2FFA9699-1E24-418F-BC67-909702BB4693.jpeg
daanvdl
I actually did create a few new SE/30 Bolle boards with all new parts as spare boards
(Yes, it was a pain to find all the parts new/NOS..)
The last part to complete these boards “visually” is this bracket:)
zefrenchtoon
@robin-fo , @Big Ben & others
I am in France and would be in for one if you make an order or if there is a spare available.
No stress for me. I can wait 🙂
Then if you have source for components … it would be great 😅
Big Ben
I should receive a board from Robin soon. I didn't start working on getting components yet. I need to check what is salvageable from my board before.
robin-fo
I only have a single spare board left which I intended to build myself once I finished my Classic Reloaded board. If it should turn out that I won‘t have time to build it in the next months, I might sell it including all relating components (almost everything except the ASICs).
I can also help with my mouser parts list if somebody is interested…
macintosh2002
Grüezi, I would be interested in your mouser parts list, I´ll order some boards too and need some parts. Thank you
