Macintosh SE/30 logicboard recreation (thread revival)
daanvdl
Hi all,
I created a 3D STL model for the RESET and INTERRUPT button right angle support (for use with the ALPS SKHCBHA010).
It doesn't have the bottom prongs but I found out that it doesn't affect the firmness much.
This model will fit on the original and the Bolle board.
You can download it over here:
https://van-de-lagemaat.com/se30/bottenholder-final.stl
3D Printer settings:
80% infill
0.2mm quality
no support
cannfoddr
I am in the UK and am thinking about ordering some of these. Basic green boards with the bottom side populated from the BOM/Parts Placement. I have at least one donor board that is in pretty bad shape.
1. Is anyone else interested in one of these - looks like minimum order is 5?
2. Can anyone give me a quick rundown of which options I need to specify from JLPCB - board thickness, etc...?
Thanks
APPLCOLC
Is this still being sold?
edit: My bad I misread parts of the thread. Don’t answer the question, my apologies.
APPLCOLC
Is this sold as a completed kit or is it just a board file with a BOM?
I apologize if I’m being a dumbass here.
xporadio
I have my boards on the way, and I have an old mac IIcx board that I will be harvesting all the parts from. I will let everyone know the progress as I'm curious to see how many of the parts required will be available on the IIcx board. It looks like most of them will work when comparing images of an Se/30 board and a IIcx. Of course I will be ordering dip sockets, PGA cpu, pga socket, roms seperately.
rplacd
Off-topic question to people assembling boards: are y'all scavenging from bombed boards, or is there a source for NOS ASICs that I'm somehow missing? I've been looking far and wide for a replacement for an SE/30 GLUE chip that might be malfunctioning.
I think anyone that claims to have lots of ASICs for these should probably be treated with moderate suspicion, unfortunately. As far as I know there's no reliable source other than bombed boards.
daanvdl
For those who are interested;
I measured the ferrite beads located at L22,L20,L19,L18,L17,L16,L15,L14,L13,L12,L11,L10,L9,L8 with my VNA.
Hereby a sweep resistance output from 1Mhz to 500Mhz.
M1 is at 100Mhz 92Ohm with a low Q factor.
Taiyo Yuden FBMJ4516HS111-T is matching this curve.
daanvdl
Anyone have a clue? Doesn’t seems to be related to ROM, RAM, VIAs, SCSI PLCC or FPU. Removing them doesn’t affect the pattern).
