Macintosh Plus - Wobbly picture, collapsed height
joshc
I have a Plus with a recapped logic board and analog board (work carried out by me).
It worked perfectly before I put it into storage.
I've just taken it out of storage, I think I last turned it on a few months ago.
Now the picture is very wobbly and the picture height has collapsed.
Any ideas as to what is causing this behaviour?
I have checked the ground points and everything is still screwed together as it should be...
See videos below
View attachment IMG_0540.mp4
View attachment IMG_0543.mp4
View attachment IMG_0541.mp4
techknight
They dont play. just show white screens. Should use a service like google drive, or some other uploader/video embedder.
techknight
thats an open capacitor somewhere. your getting 120hz noise into the horizontal deflection.
if you have already recapped this board, you should go back and double-check all of your work. And have you replaced EVERY capacitor? including the main primary input filter capacitor?
joshc
That seems very odd because after the recap this worked perfectly, its only after being in storage that its had this weird problem.
I replaced all capacitors yes.
I will check them all again...
techknight
Figured. I knew it was an open capacitor somewheres.
At least you got it going :)
