Macintosh IIsi Magic chime sound. What does it mean?
zezba9000
Got a Macintosh IIsi computer.
1) Got computer.
2) After plugging it in, it auto turned on? This doesn't seem right, PSU maybe?
3) The screen would show gray, then go off and make an error chime.
4) So I replaced the caps as I thought that might be the root issue (sound was super low as well).
5) Now I have the same issue (but load sound). So computer auto turns on when power plugged in and screen goes on then off and makes a error chime sound.
6) I replaced the ram with "confirmed working" 4 256kb dimms for a total of 1mb but have the same issue.
Any ideas? My only idea is PSU but idk. I also washed motherboard as caps probably leaked but maybe I need to wash more?
Video of issue: https://photos.app.goo.gl/TNdpiKy4Tk6m1b8f8
First beep is my bird so ignore that lol. Any ideas are welcome!
zezba9000
Also is there another PSU that can be used on these computers for testing?
I'm reading these can go bad in IIci computers so guess its the same with IIsi?
bibilit
On the back of the IIsi, the power button can be turned 90° to switch on when plugged to the wall.
CC_333
I *think* a IIcx/ci PSU is electrically compatible?
The IIsi is quite unique, so most parts form other machines (aside from disk drives, cables, and other such things) won't work without some effort.
c
bibilit
Maybe have a try with another PSU, did you recap the PSU ?
Those can be tricky to repair, but depending of the supplier, a lot of capacitors to replace.
zezba9000
I only replaced the caps on the motherboard (47uf - 16v to 47uf - 50v).
I might just use the MacCaps service to get the PSU done.
zezba9000
So opened up the PSU and thats got to be the issue (should have taken a picture).
The caps that look like they're on the board that control the on/off switch look messed up and super leaky.
Man this PSU was the dumbest design. To fix the caps on this are just way more work then it should be, its wonky as **** in there.
Apple really did the wackiest job on these computers I have ever seen. The speaker, power led and back fan are all just surface contacts... the PSU is a joke of a design.
I sent it into MacCaps to get repaired. Cost 75$ because of how crazy these are.
The computer is in really good shape all things considered so I have high hopes.
Will report back once I get the PSU back (fingers crossed)...
AlpineRaven
Why did you install to 50v 47uf caps?
There is also axial caps on the board as well - they may need replacing to.
100% for sure the PSU does need recap - It has known it gets shorten to start it up on its own.
Yes IIci/Quadra 700 PSU does fit on IIsi board - I've done that to eliminate the power on test/shutdown test etc.
FYI - Maccaps is not 100% accurate some caps may be different as per spec so double check what you're replacing to same value.
Cheers
AP
Zippy Zapp
I recapped my IIsi, with exception of the axial caps, which I now have.  The originals were supper clean.  The caps in my IIsi were not leaky at all but I replaced them all the same.
About the PSU, how do you open it up?  Mine seems to have no screws but perhaps rivets?  Not sure.  Mine seems to be made by Magnetek (www.magnetek.com)  Made in Italy, it appear.  Sticker on the supply says 26th week of 1992.  My IIsi must be a later model.
bibilit
Don't remember, but screws are provided for the PSU.
IIRC Sony are affected by the capacitor problem, not the Magnetek ones.
Zippy Zapp
Thanks for the info.  I had read about the bad caps with the Sony ones too but never really read anything about the Magnetek PSUs.
When I get some time I will have to have another look at it.
zezba9000
Cheers
AP
"Why did you install to 50v 47uf caps?"
-- Because its what I had. The voltage doesn't matter as long as its not less than 16v.
"Maccaps is not 100% accurate"
-- Well paid 75$ + shipping to have them replaced so sure hope it works.
zezba9000
"About the PSU, how do you open it up?"
-- You take off a screw or two then slide the top off. After that there are screws inside behind stuff... its such a dumb design.
tanaquil
Re: not 100% accurate, I think what was meant is that power supplies can vary slightly from the factory. I believe Maccaps says on his own site that the values shown for caps in the photos can vary and that users should double check the values before doing their own replacements. If you sent the supply to him to do the work, I am sure it will be fine.
On the the topic of PSUs, has anyone else found it unusually difficult to open SE/30 PSUs? I have two whose screws will not respond to any amount of force, and I usually have no trouble getting leverage on stubborn screws. I finally gave up but wondered if this was common.
Zippy Zapp
Thanks,  I will check it out.  When I first took the PSU out I didn't see a single screw but perhaps I over looked it.
9166188
I have a similar problem.  You can find my post back in 2016.  Recapped both the motherboard and PSU -- did not help.  The problem remains.
I have found others having similar issue with IIsi.   It looks like a common hard problem that is likely similar or even the same.   I have a feeling if one got fixed, many IIsi machines could be saved.  Good luck!
zezba9000
So maccaps.com guy "Charles Phillips" is not responding to any of my emails and its been 3 weeks.
I sent him my PSU 3 weeks ago. Messaged once after two weeks to see what an ETA might be... he didn't respond a week after. Also emailed him yesterday and still no answer.
Is this guy still alive or am I being scammed? Iv'e spent 100$ to get that PSU fixed.
Going to try and send him an email over a VPN on a different email acting as someone else to see if its just me hes not responding too.
If so am going to confront him about it... this is just not cool. Not in a rush just need a response.
zezba9000
Did you ever try this:
