PacificState
Having figured out the first of two Macintosh 128 boards I acquired (https://68kmla.org/bb/index.php?threads/macintosh-128k-board-with-custom-512kb-upgrade.48789/), I'm now trying to repair the second. I'll add pictures shortly, but it appears to be an 128KB board upgraded to 512KB, which unfortunately boots to a checkerboard pattern.
Few things:
- For testing purposes, I'm running this board with the DosFox ATX + VGA adapter, rather than installing it in the Mac itself. I think the checkerboard pattern can be induced by a low 5V rail, but the first board works fine with this setup.
- The board came with a note saying 'BAD RAM AND ROM SOCKETS'. As I have a desoldering gun and believe bad ROMs can result in the checkerboard, I've swapped out the sockets with new ones and also swapped in the ROMs from the first board - all without effect.
Even if the RAM is bad, I don't know it would cause this problem - from what I can see, this is a symptom of the ROM not getting to run and clearing the screen. I'm therefore wondering if it's either the 68000 or the 6522. I have a scope, so I can start probing lines tomorrow - are there any particular things to check, though? Thanks!
Few things:
