Test System: Amiga 1200, 57 mhz m68060
MacBench Version: MacBench® 4.0
Organization: Guru
Test Date: Tuesday, July 8, 1997 9:02:20 AM
Test Name Result Units
Processor Tests:
Processor: 67 score
Floating Point Tests:
Floating Point: 40 score
Disk Tests:
Disk: 187 score
Publishing Disk: 188 score
Sequential Read 512: 481.97 kilobytes/sec
Sequential Read 1K: 874.32 kilobytes/sec
Sequential Read 32K: 3830.50 kilobytes/sec
Sequential Read 64K: 4710.01 kilobytes/sec
Sequential Read 128K: 4704.70 kilobytes/sec
Sequential Read 1024K: 4707.59 kilobytes/sec
Custom Seq Rd 1024: Test not run
Random Read 512: 48.63 kilobytes/sec
Random Read 1K: 94.02 kilobytes/sec
Random Read 32K: 1536.45 kilobytes/sec
Random Read 64K: 2617.98 kilobytes/sec
Random Read 128K: 3304.43 kilobytes/sec
Random Read 1024K: 4469.30 kilobytes/sec
Custom Ran Rd 1024: Test not run
Sequential Write 512: 2196.45 kilobytes/sec
Sequential Write 1K: 2630.11 kilobytes/sec
Sequential Write 32K: 3295.97 kilobytes/sec
Sequential Write 64K: 4713.33 kilobytes/sec
Sequential Write 128K: 4723.96 kilobytes/sec
Sequential Write 1024K: 4730.00 kilobytes/sec
Custom Seq Wr 1024: Test not run
Random Write 512: 69.90 kilobytes/sec
Random Write 1K: 130.48 kilobytes/sec
Random Write 32K: 1598.71 kilobytes/sec
Random Write 64K: 2599.34 kilobytes/sec
Random Write 128K: 3357.02 kilobytes/sec
Random Write 1024K: 4493.73 kilobytes/sec
Custom Ran Wr 1024: Test not run
Graphics Tests:
Graphics: 174 score
Lo-Res Publishing Graphics: 163 score
Hi-Res Publishing Graphics: 168 score
EraseArc: 7650.07 kilopixels/sec
FillArc: 7643.52 kilopixels/sec
FrameArc: 115.94 kilopixels/sec
InvertArc: 8790.29 kilopixels/sec
PaintArc: 8715.50 kilopixels/sec
CopyBits - srcCopy: 13371.96 kilopixels/sec
CopyBits - srcOr: 9805.30 kilopixels/sec
CopyBits - srcBic: 9446.88 kilopixels/sec
CopyBits - srcXor: 9824.27 kilopixels/sec
CopyBits - notSrcCopy: 1608.23 kilopixels/sec
CopyBits - notSrcOr: 8163.17 kilopixels/sec
CopyBits - notSrcBic: 8159.30 kilopixels/sec
CopyBits - notSrcXor: 9819.97 kilopixels/sec
CopyBits - addOver: 1059.23 kilopixels/sec
CopyBits - addPin: 1737.63 kilopixels/sec
CopyBits - subOver: 1037.56 kilopixels/sec
CopyBits - subPin: 1711.77 kilopixels/sec
CopyBits - adMax: 1755.05 kilopixels/sec
CopyBits - adMin: 1593.61 kilopixels/sec
CopyBits - blend: 863.45 kilopixels/sec
CopyBits - transparent: 6675.91 kilopixels/sec
CopyBits - hilite: 9812.19 kilopixels/sec
CopyBits - CopyMask: 523.18 kilopixels/sec
CopyBits - CopyDeepMask: 522.75 kilopixels/sec
CB - DrawPicture: 1131.01 kilopixels/sec
CB - DrawPicture (scaled): 912.94 kilopixels/sec
CB - ScrollRect: 17016.76 kilopixels/sec
LineTo - Horizontal: 1682.13 kilopixels/sec
LineTo - Vertical: 896.09 kilopixels/sec
LineTo - Diagonal: 1.58 kilopixels/sec
EraseOval: 15134.47 kilopixels/sec
FillOval: 15033.40 kilopixels/sec
FrameOval: 335.42 kilopixels/sec
InvertOval: 16478.79 kilopixels/sec
PaintOval: 16362.19 kilopixels/sec
ErasePoly: 2946.66 kilopixels/sec
FillPoly: 2690.59 kilopixels/sec
FramePoly: 217.80 kilopixels/sec
InvertPoly: 3320.12 kilopixels/sec
PaintPoly: 3281.31 kilopixels/sec
EraseRect: 23626.41 kilopixels/sec
FillRect: 20314.91 kilopixels/sec
FrameRect: 1222.43 kilopixels/sec
InvertRect: 23740.36 kilopixels/sec
PaintRect: 23652.89 kilopixels/sec
EraseRgn: 23640.89 kilopixels/sec
FillRgn: 20336.20 kilopixels/sec
FrameRgn: 1191.09 kilopixels/sec
InvertRgn: 23776.77 kilopixels/sec
PaintRgn: 23688.68 kilopixels/sec
EraseRoundRect: 19081.95 kilopixels/sec
FillRoundRect: 18852.98 kilopixels/sec
FrameRoundRect: 731.97 kilopixels/sec
InvertRoundRect: 20707.81 kilopixels/sec
PaintRoundRect: 20560.43 kilopixels/sec
DrawChar: 18.10 kilopixels/sec
DrawString: 359.31 kilopixels/sec
DrawText: 199.30 kilopixels/sec
CD-ROM Tests:
CD-ROM: 415 score
CD Sequential Read 512: 10.54 kilobytes/sec
CD Sequential Read 1K: 30.53 kilobytes/sec
CD Sequential Read 32K: 586.62 kilobytes/sec
CD Sequential Read 64K: 589.10 kilobytes/sec
CD Sequential Read 128K: 596.88 kilobytes/sec
CD Sequential Read 1024K: 619.25 kilobytes/sec
Custom CD Seq Rd 1024: Test not run
CD Random Read 512: 5.59 kilobytes/sec
CD Random Read 1K: 10.91 kilobytes/sec
CD Random Read 32K: 218.10 kilobytes/sec
CD Random Read 64K: 325.08 kilobytes/sec
CD Random Read 128K: 419.77 kilobytes/sec
CD Random Read 1024K: 564.67 kilobytes/sec
Custom CD Ran Rd 1024: Test not run
Video Tests:
Frames Played - CinePak 1: 88.44 percent
Frames Played - CinePak 2: 23.11 percent
Frames Played - Motion JPEG-A: 6.11 percent
Frames Played - Uncompressed: 2.22 percent
Custom Frames Played: Test not run
Max Frame Rate - CinePak 1: 21.16 frames/sec
Max Frame Rate - CinePak 2: 11.04 frames/sec
Max Frame Rate - Motion JPEG-A: 5.25 frames/sec
Max Frame Rate - Uncompressed: 3.94 frames/sec
Custom Max Frame Rate: Test not run
General Information:
System Vendor: Amiga International
Model: Amiga 1200
Processor Type: Motorola 68060
Processor Speed (MHz): 57
Bus Speed (MHz): 57
ROM Size (KB): 1024
Addressing Mode: 32-bit
Interleaved Memory: no
Memory Size (KB): 55000
Virtual Memory (KB): Off
L1 Cache Size: 8KB instruction, 8KB data
L2 Cache Size (KB): 0
Disk Cache Size (KB): 384
FPU Type: 68060 Built-In FPU
MMU Type: 68060 Built-In MMU
System Version: 7.6.1 (Update 1.0)
Finder Version: 7.5.6
AppleTalk State: Inactive
File Sharing: Off
Modern Memory Manager: n/a
RAM Disk (KB): Off
Async I/O Capable: No
Storage Devices:
Volume Name: Astarte (Amiga DeviceDisk)
Device Type: Direct-Access
Vendor:
Product Model Number:
Revision Number:
Driver/Formatter: unknown
Driver/Formatter Version: unknown
Capacity (MB): --
Number of Cylinders: --
Number of Heads: --
Sectors per Track: --
Bytes per Sector: --
Interleave: --
Boot Volume: Yes
Volume Name: Lilith (SCSI ID 1)
Vendor: SEAGATE
Product Model Number: ST31230N
Revision Number: 0640
Capacity (MB): 1010
Number of Cylinders: 3992
Number of Heads: 5
Sectors per Track: 104
Bytes per Sector: 512
Interleave: 1
Boot Volume: No
Volume Name: MacBench® 4.0 CD (SCSI ID 4)
Device Type: Read-Only Direct-Access
Vendor: SONY
Product Model Number: CD-ROM CDU-76S
Revision Number: 1.1c
Capacity (MB): --
Number of Heads: --
Interleave: --
Boot Volume: No
Display Devices:
Graphics Card Name: Amiga AGA
Graphics Card Driver: TurboEVD
Graphics Card Driver Version: 34.1
Card Slot: $0
Graphics Memory (KB): 2 meg of Chip RAM
Resolution (pixels): 1152 x 870
Dot Pitch (mm): 0.35 x 0.35
Current Bit Depth: 8
Movies:
Movie Name: 160x120 CinePak
Original Frame Rate (fps): 15.00
Original Duration (seconds): 30.00
Average Data Rate (KB/s): 117.11
Original Size (pixels): 160 x 120
Pixel Depth (bits/pixel): 24
Codec: Cinepak (1.1)
Sound Channels: 1
Sound Data Format: Raw
Sound Sample Size (bits): 8
Sound Sample Rate (KHz): 22.05
Movie Name: 320x240 CinePak
Average Data Rate (KB/s): 357.92
Original Size (pixels): 320 x 240
Sound Channels: 1
Movie Name: 240x180 Motion JPEG-A
Original Frame Rate (fps): 30.00
Average Data Rate (KB/s): 1014.08
Original Size (pixels): 240 x 180
Codec: Motion JPEG A (1.1)
Sound Channels: 1
Movie Name: 240x180 Uncompressed
Original Duration (seconds): 15.00
Average Data Rate (KB/s): 3969.14
Codec: None
Sound Channels: 2
Sound Data Format: Twos Complement
Sound Sample Size (bits): 16
Sound Sample Rate (KHz): 44
System Files:
Control Panel: Apple Menu Options (1.1.2)
Control Panel: AppleTalk (1.1)
Control Panel: Color (7.1)
Control Panel: Date & Time (7.5.1)
Control Panel: File Sharing Monitor (7.1)
Control Panel: General Controls (7.5.
Control Panel: Keyboard (7.5.1)
Control Panel: Labels (7.1)
Control Panel: Mac OS Easy Open (1.1.3)
Control Panel: MacTCP DNR
Control Panel: Map (7.5.1)
Control Panel: Memory (7.5.7)
Control Panel: Modem (1.0)
Control Panel: Monitors (7.5.6)
Control Panel: Mouse (7.5.4)
Control Panel: Numbers (7.1)
Control Panel: PC Exchange (2.1.1)
Control Panel: PPP (1.0)
Control Panel: Sharing Setup (7.1)
Control Panel: Sound (8.0.5)
Control Panel: Startup Disk (7.5.3)
Control Panel: TCP/IP (1.1.2)
Control Panel: Text (7.1)
Control Panel: Users & Groups (7.1)
Control Panel: Views (7.1)
Control Panel: WindowShade (1.3.1)
Control Panel: ~ATM™ (3.9)
Extension: EM Extension (4.0)
Extension: Apple CD-ROM (5.4)
Extension: AppleScript™ (1.0.1)
Extension: ColorSync™ (2.1.1)
Extension: File Sharing Extension (7.6.2)
Extension: QuickTime™ (2.5)
Extension: QuickTime™ Musical Instruments (2.5)
Extension: Shared Library Manager (2.0.1)
Extension: Suitcase™ 2.1.4 (2.1.4)
Extension: Type Reunion (1.2)
Test Settings:
Selected FPU: Hardware FPU
Selected Hard Disk: Lilith (SCSI ID 1)
Selected Graphics Card: Amiga AGA
Selected CD-ROM: MacBench® 4.0 CD (SCSI ID 4)
Standard Movies Source: CD-ROM
Custom Movie Aligned: n/a
Custom Movie In RAM: n/a
Custom Movie Playback Size: n/a
Comments:
Using ShapeShifter 3.8 & 1 meg ROM on a Blizzard 1260 (m68060)with SCSI-IV DMA SCSI-2 Fast controller.
Notes:
