Mac SE sound messed up with Radius accelerator
RadRacer203
Just installed a 16mhz Radius accelerator in my SE and I can definitely see the difference, it's significantly faster than stock. One quirk I've found though is the sound seems to be messed up. There's a lot of static in any music or anything more than just a simple beep. I'm stumped, do I need to install special software for this Radius board to fix it? I'm not sure where to start. I did confirm it wasn't the logic board by swapping in a known perfect one from another SE.
RadRacer203
Looks like the drivers solved it! That was a way longer process than I expected cause I wasn't set up for making Apple disks yet...
aplmak
Hey I know this is a very old post but does anyone have these drivers?? The site doesn't appear to have them any longer unfortunately.... Thanks in advance!
JC8080
Did the drivers fix the sound problem? I have the 25mhz board and I don't have any sound issues, though I only tested after I installed the drivers, so I can't confirm whether the problem existed without them.
