Looks like you lost your vertical deflection. This could be an easy fix, or might require some troubleshooting of the analog board. The first thing I would check is the solder joints on the back of neck board, especially the ones that connect to the CRT pins. I would also check the neck board connector joints on the back of the analog board. All of those are prone to cracking and coming loose.
